If printing quality problems occur or if you use your machine in a dusty environment, you need to clean your machine regularly to keep it in the best printing condition and use your machine longer.
Clean the machine cabinet with a soft, lint-free cloth. Dampen the cloth slightly with water, but be careful not to let any water drip onto or into the machine.
Keeping the scan unit clean helps ensure the best possible copies. We suggest that you clean the scan unit at the start of each day and during the day as needed.
Slightly dampen a soft, lint-free cloth or paper towel with water.
Lift and open the scanner lid.
Wipe the surface of the scanner glass until it is clean and dry.
Wipe the underside of the scanner lid and white sheet until it is clean and dry.
Close the scanner lid.
